1970 hot water valve - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Hello all! This weekend we replaced the hot water valve on a fellow chapter member's 1970 A/C small block car. This car is a very low mile, very original example. Below are pictures of the valve we removed and we would like opinions as to whether this is an original part. What we found interesting is the stud next to the vacuum port that had a small round retainer on it that held the vacuum hose in place. The hose itself has a plastic fitting on the end that slipped over the stud. "Type H 25" and "Ranco" is stamped into the part. Thanks for your input.
    Jeff
    • 11643
    Re: 1970 hot water valve
    I like it. It looks similar to what I once removed from my 71.
    • Jeffrey S.
      • May 31, 1988
      • 1882
      Patrick,
      Thanks for the response. We didn't have a '70 AIM to compare the part number with the '69 part # which we had with us. My '69 valve, when removed, was more like the replacement valve where the hose just pushes on. Can you give me the part number fro the '70 AIM for comparison?
      Jeff
        • 11643
        Originally posted by Jeffrey Salz (13182)
        Patrick,
        Jeff
        Jeff,
        I only have the 71 and 72 AIMs at home.
        • Jeffrey S.
          • May 31, 1988
          • 1882
          I have the '72 as well and by then the valve wasn't used (at least it doesn't appear in the AIM).
          Jeff
            • 43221
            Patrick,
            Jeff
            Jeff------
            1969 used valve GM #3949878. I can't find that this valve was ever available in SERVICE. For SERVICE, the valve was GM #3940250. I have no idea how they differed, if at all.
            The early 1970 valve was also the GM #3949878. Later 1970 used valve GM #3984642. This valve also became SERVICE for 1969 when the 3940250 was discontinued in June, 1971.
            GM #3984642 was later discontinued and replaced by GM #3984641. The latter was discontinued without supercession some time ago.
            • Jeffrey S.
              • May 31, 1988
              • 1882
              Joe,
              Thanks for the part numbers. Is it possible that the service part was the same as the assembly line part except that the mounting screws were included generating a different part number?
              Jeff
                • 43221
                Joe,
                Jeff
                Jeff-----
                Yes, that's possible. In any event, I really don't think there was any difference, at all, in the 3949878 and the 3940250.
                I think the only difference between these two and the later 3984642 is that the former have a straight vacuum nipple and, perhaps, some sort of mounting stud nearby while the 3984642 has a curved vacuum nipple and no mounting stud, at all.
                • James B.
                  • March 1, 1985
                  • 217
                  Jeff
                  Do we know why this type of valve wasn't installed beginning with the 1972 model?
                    • 43221
                    James------
                    I don't know but I expect GM figured that if they could get by without the valve for cars without air conditioning, then they could also get by for cars with air conditioning.
                    A valve came back for 1975 but only for Corvettes without air conditioning. For 1976-82, all Corvettes had a valve.
                    • Timothy B.
                      • April 30, 1983
                      • 5186
                      Joe,
                      I am helping my Brother with a low mile late produced 75 Corvette roadster with A/C.
                      I want to back flush the heater core but did not know if this car had a hot water valve. Am I correct to assume no valve and OK to back flush? the core.
                        • 43221
                        Originally posted by Timothy Barbieri (6542)
                        Joe,
                        Timothy------
                        If the 1975 had A/C, then it should have no valve. Is it OK to back flush? I would assume so.
                        • John V.
                          Infrequent User
                          • February 5, 2014
                          • 3
                          Jeff, Thank you for posting the thread and pictures.
                          Joe, Your insight is appreciated. Based upon what you identify as the "straight" vacuum nipple w/ stud...the valve pictured is a 3949878.
                          I am now reviewing my 1970 AIM -sheet D4. Note#2 dated 12-12-69, for (Sym #2) states: WAS 3949878 VALVE ASM.
                          It would appear there were still some 3949878 valves that made it into at least January 1970 production.
                          My VIN ...2127; built Jan. 28th, 1970.
                          Would you agree?
                            • 43221
                            Would you agree?
                            John------
                            Definitely. I would expect the 3949878 at least through January, 1970 if not well beyond that time.
                            • Reba W.
                              • 937
                              It was not on my Sept. 24-built 1972 with AC.
