'69 Conv. door jamb/water diverter - NCRS Discussion Boards
  • Joel A.
    • September 30, 1997
    • 214
    Can anyone post a pic(or more) of the rear door jamb area on a '69 convertible? I need pics of the (OE) door guide(s), and water diverters to verify the correct locations, plus to make sure the parts in hand are correct for a '69, since other years are different. Trying to help a good friend finish up some of the final details on a 10 year project...it's gettin close!
    tia
    Joel Adams
    1974 Coupe
    1985 Coupe
    "I know the voices aren't real...but sometimes they have some really kewl ideas...."
  • John C.
    • January 1, 2005
    • 616
    Re: '69 Conv. door jamb/water diverter
    Joel
    Attached are a couple pictures of the diverters and one of the entire door jam.
    There will be some variations in the diverter depending on when the car was built. Very early cars will have a rubber strip that is glued in place. Most cars had a fiberglass strip that was glues on. On very late production cars the strip will be riveted on.
    The pictures are of a Dec. 68 built car with the glued on fiberglass strip.
    John
    • Joel A.
      • 214
      Thanks John. Is that a convertible car? It doesn't have the door guides is why I ask. The diverter pics will help, anyway. Now I gotta get back to werk...groan....
      Joel Adams
      1974 Coupe
      1985 Coupe
      • John C.
        • January 1, 2005
        • 616
        Yes it is a convertible. In 69 alignment wedges were used on the convertible doors. You can see it above the striker in the picture.
        1970 was the first year of the door guides as shown in the picture below.
        • Edward B.
          • March 29, 2013
          • 691
          Joel, you didn't say when the car was assembled, but here's a picture of the riveted strip on my late 1969 (built October 21st, 1969).
          The TIM&JG shows the fiberglass strips started "at least by 6,612", and were glued on to about 28,242. Then sometime after that, the strips were riveted in place. The AIM revision for the addition of the rivet (UPC 1, Sheet B9, item 8, note 5) was February 10th, 1969, but of course, it could have been before or after that since the notes in the AIM aren't necessarily the exact date the change was made.
          Ed
          • James B.
            • March 1, 1985
            • 217
            Were door water diverters only installed on convertibles (and only for selected model years)?
            • Reba W.
              • 938
              Th diverters began as glued foam strips sometime during 1968 production (TM&JG says April 1968) and evolved to glued fiberglass and then riveted fiberglass during 1969. They were on both coupes and convertibles through 1971. I have a 1972 and have always wondered why it was eliminated since water enters the car if it is not there.
              • Joel A.
                • 214
                Thanks folks! These pics will certainly help. Later cars used an aluminuminum diverter with a rubber strip on them.
                Not sure what the build date is on this one...I'll look and see, and post.
                Joel Adams
                1974 Coupe
                1985 Coupe
                • Reba W.
                  • 938
                  I think that later style began with 1974 production. In fact, I have added them to my 1972 to solve the water problem. diverter.jpg
                  • Larry M.
                    • December 1, 1986
                    • 541
                    I added the same aluminum/rubber diverters to my 1972 as well, with a thin film of black silicone behind the rubber as insurance. Does a super job of keeping water out.
                    As of 1982, the part #'s in group 10.355 were 342295 and 342296 for 1974 to 1977 applications.
                    • Joel A.
                      • 214
                      Thanks folks. The pics and info helped!
                      Joel Adams
                      1974 Coupe
                      1985 Coupe
                      • Floyd B.
                        • November 1, 2002
                        • 1050
                        Sorry to highjack the thread but I have an additional question. Were alignment wedges always installed on both sides or only on cars that exhibited less than acceptable alignment? My early Oct '68 car has the screw holes for the wedge on the passenger side but the wedge is missing. The driver side has no wedge nor screw holes (or any evidence that a wedge was ever installed).
                        Thanx
                        "Drive it like you stole it"
                        • Edward B.
                          • March 29, 2013
                          • 691
                          Although mistakes "could" be made, according to the TIM&JG:
                          Early 1968 coupes and convertibles have a gray plastic body-jam alignment block and later ones have a long brass door-alignment wedge.
                          Ed
