Re: 1967 Convertible Door Panel Fit Issues
After removing the glass from the sash I reset it using new set tape to the proper position, 3/4" at the rear and 1/4" at the front, protruding so it glides in the forward channel properly.
It took some work to remove the glass. I used 3M Adhesive cleaner to soften the old set tape and a knife to remove it all then I removed the glass. It was a stubborn one.
I reinstalled the glass assembly in the door and reset the vent window frame adjustments to get the proper alignment. Now the vent frame is parallel to the windshield. before this effort, there was more gap at the top then at the bottom.
I adjusted the glass sash stops to fit to the soft top, reinstalled the door panel, and all is much better. I replaced the aged rear channel felts on both sides while in there. The originals were quite work and faded. I also touched up all of the missing black paint in the trim racetracks, using a detail brush and flat black paint.
P3310005.jpgP3310006.jpgP3310007.jpgP3310008.jpgP3310010.jpgP3310011.jpgP3310012.jpgP3310013.jpg
Done. Before I installed the panel with it's modified "clip" to hold it against the vent frame better, I glued on some black felt to help hide the gap and hide the door internal parts from view. NTP but looks more finished and detailed this way.
Rich
Rich
