Replacement Leaf Spring Bands--Should They be Removed?? - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    The replacement rear leaf springs have a one band on each end that is not present on the original. Should those be removed? I read one post that said these prevent damage when the springs rebound and that the original would have been better if they had them. I can remove them to prevent judging points deduction but the question is: will the spring function and last longer if left on? Thank you for your help.
    • 11689
    Re: Replacement Leaf Spring Bands--Should They be Removed??
    Paul,
    Just remove them. They are essentially only present for shipping purposes to keep the leaves from rotating/spreading.
    Patrick
      • 43263
      Paul------
      Does the replacement spring have plastic spring liners with raised edges that align the leaves or are the liners completely flat?
      • Paul C.
        • November 12, 2007
        • 511
        They are completely flat.
        • Gary B.
          • February 1, 1997
          • 7060
          Paul,
          If the liners don''t have the H profile, they are not correct from the judging perspective. Proper liners with the raised edges are available from Quanta Products, I think. And from Eaton Detroit Spring.
          Gary
            • 43263
            Paul------
            In the case of flat spring liners, you may need the end bands to ensure the leaves stay aligned. It is true that the spring clamp bolts (i.e. from center plate to differential cover) serve to maintain leaf alignment. However, they will still allow slight misalignment if flat spring liners are used.
            • Paul C.
              • November 12, 2007
              • 511
              Thank you. Would someone please post a picture of an original 1971 or close year of the correct spring with the correct liner. Thank you.
              • Lawrence M.
                • February 1, 1995
                • 404
                Hi Paul,
                Attached is a photo of an original 1969 spring restored with NOS GM liners.
                Larry
                2002 Z51 Convertible
                1969 L46 Convertible
                • Paul C.
                  • November 12, 2007
                  • 511
                  Lawrence--THANK YOU for taking the time to post the pictures. It is greatly appreciated. Paul
                    • 43263
                    Paul------
                    The 9 leaf spring was essentially unchanged from 1964 through 1974. So, your 1971 spring should appear identical to the 1969 spring pictured.
