I have an early 60 Corvette (Oct 60) and the rear end housing has the vent tube and circular Limited Slip tag under the filler plug. From what I learned from the forum is that this is a Posi carrier. However, I have the following numbers on the center section: P/N 3725899, H297, BB011. I checked the rear wheel rotation when the driveshaft is rotated and the wheels rotate opposite. I have Alan Colvin's "Corvette By the Numbers" book and it doesn't mention this 3725899 part number. Is this a Non-Posi passenger center section? And my big question is, can I simply swap this center section with a Posi unit or will the axles have to be changed, also?
Thanks in advance,
Pete
Thanks in advance,
Pete
