75 roadster seat issue - NCRS Discussion Boards
  • Ross F.
    • August 31, 2004
    • 167
    Hello,
    i rebuilt my seats. New foam and covers. They look great. But I must have done something wrong. When I flip the seat backs into the upright position, they don't lock. I don't think the catch is locating into the hole on the metal strap the runs up the seat back.
    any ideas?
    • 11643
    Re: 75 roadster seat issue
    Push the seatback backwards gently and see if it clicks into place.
    Odds are that 1) the foam is too thick, and the seat isn't going back far enough, or 2) the stops at the rear corners are too long. Adjust those shorter if the idea above doesn't work.
    • Alger R.
      • September 30, 1999
      • 279
      You could always remove the bolts holding the lock strap to the seat bottom and see if the strap slides properly and latches in place. If so, set the strap in the locked position and push the seat back and check the fit between the strap attachment and the seat bottom. if the seat strap doesn't quite reach the seat bottom, the you can assume that the bumpers and bumper stops have to be adjusted.
      AL
      75 Convertible
      L48 M20
      Bright Green / Saddle
      • Ross F.
        • August 31, 2004
        • 167
        Thanks for the reply,
        I will try that. But won't that result in the seat back "laying back" I'm already hitting the top lid when the seat is pulled al the way back.
        • Alger R.
          • 279
          I am not sure of how much additional angle you would get by lowering the bumpers. There would be some but how much I don't know. Hopefully Maybe not enough to hard hit the deck lid. The deck lid does have the two bumpers for that reason. You might also try adding an additional or thicker plastic shim between the lock strap bottom attachment and the seat bottom cushion. (As an FYI, when I replaced the bumpers from my conv top deck lid they definitely showed signs of wear from the seat back bumping them)
          AL
          75 Convertible
          L48 M20
          • Harmon C.
            • August 31, 1994
            • 3228
            In ever car when new their was a cloth bag with 1/8" shims to raise the seat back forward.I had to remove all the foam from under where the seat back lock bolts to the bottom seat frame to get my 75 to lock.
            Lyle
            • Ross F.
              • August 31, 2004
              • 167
              Is there an after market source for the plastic shims. It will lock if I unbolt the strap from the seat base. So I believe a couple shim will do it.
              • Harmon C.
                • August 31, 1994
                • 3228
                The shims should be easy to find from most vendors. They are made of
                metal.
                Lyle
                • Ross F.
                  • August 31, 2004
                  • 167
                  Thanks for the replied.
                  I did purchase the shims and bag.
                  Funny story..... they didn't help.
                  You see there is a front and back when mounting the catch strap to the seat bottom. The loop holding the strap has to be at the back.
                  50-50 and I'm wrong every time.
