56 Early dipstick Tube picture/dimensions - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    i am looking for a picture and dimensions of the early 56 dipstick Tube
    so i could fabricate one
    thank you Sander,
  • Gary C.
    Administrator
    • October 1, 1982
    • 17771
    Re: 56 Early dipstick Tube picture/dimensions
    Sander,
    What is the early 1956 VIN ?
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Sander B.
      • March 1, 2005
      • 499
      it is #261 Gary
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        Sander,
        Sorry, I don't have any measurements nor do I know who has one you can measure.
        Question - do you have the cast iron holder on the pan - see first photo?
        Attached are two photos; 1 - cast iron dipstick holder on pan, 2 - dipstick tube, which might give you an approximate length
        Checked the Parts Books. Part #3718206 1st design 1956 Corvette dipstick tube is 14 1/2 inch OL
        Hope this info helps.
        Gary
        NCRS Texas Chapter
        • Sander B.
          • March 1, 2005
          • 499
          thanks Gary this will help atleast i now know how it looks like i've read the overall lenght is 14.1/2 but its not clear if thats measured from the top of the cast iron holder to the top of the tube . or from where the cast iron holder is attached to the oil pan ?
          and yes i have the correct oilpan and holder on the right, but still in search of an early 56 dipstick......
          • Gary C.
            Administrator
            • October 1, 1982
            • 17771
            Sander,
            That's the OL (total) length of the tube including the part that inserts into the cast fitting on the oil pan.
            Finding an early 1956 Corvette dipstick is close to finding the holy grail. Part # 372290 only use is 1956 1st design oil pans.
            Gary
            NCRS Texas Chapter
            • David L.
              • July 31, 1980
              • 3310
              Originally posted by Gary Chesnut (5895)
              Sander,
              Gary
              Gary,
              You missed a digit. The 1956 Corvette 1st design dipstick is GM # 3722960 (not 372290) and is described as follows:
              "19 13/32 under washer" (March 1957 parts catalog)
              and
              single piece, A = 17 37/64" B = 18 27/64" (Oct. 1962 parts catalog)
              I have two original 1958 Chevrolet 283 dipsticks (GM # 3747979) made by different manufacturers that must be similar to the Early 1956 Corvette dipstick except for the length.
              Both measure about 20 5/8" under the washer.
              A = 18 35/64" and B = 19 5/16"
              One 1958 dipstick is stamped "ADD", "FULL", and with what looks like the top half of an encircled letter along with a rounded off pointed end. It also has one 1 3/4" cutout just below the washer.
              The other 1958 dipstick is stamped "ADD" , "FULL", and with what looks like the top half of a small encircled letter "B" (or maybe it's the letter "E") along with a "chisel" type pointed end. This dipstick has two 1 3/4" long cutouts spaced about 5" apart.
              The "looped" handle ends measure about 2 3/8" and 2 5/8". I have original 1961 and 1964 Chevrolet dipsticks that have much longer "looped" handles (about 4 1/4" and 4 1/2" or so).
              If necessary, I can take a few photos.
              Is there two versions of the 3722960 Early 1956 Corvette dipstick?
              Does the Early 1956 Corvette have one or two 1 3/4" cutouts?
              Does the "looped" handle end measure about 2 1/2" or about 4 1/2"? The dipstick in your photo looks like the longer handle end.
              Here are two photos of the 1958 Chevrolet dipstick with the two cutouts that I happen to have in my files.
              Dave
              • Sander B.
                • March 1, 2005
                • 499
                Made the tube a little longer for now and figure out the exact lenght
                • Sander B.
                  • March 1, 2005
                  • 499
                  got these detailed pictures from a member from the corvette forum
                  maybe interesting for some here too
                  Sander.
                  • David L.
                    • July 31, 1980
                    • 3310
                    My other 1958 Chevrolet 283 dipstick (Eng. stamped "T514C" or May 14, 1958; intake casting date "C2658" or March 26, 1958 ) appears to be the same as the Early 1956 Corvette dipstick EXCEPT for the length. The stamping at the bottom end of the dipstick appears to be the same the 9th photo in Sander's post.
                    O.L. = 23 1/4" (about 1 1/2" longer than the E56 Corvette dipstick)
                    A = 18 35/64" (31/32" or 0.97" longer)
                    B = 19 5/16" ( 57/64" or 0.89" longer).
                    Dave
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17771
                      1956 1st design dip stick end has a different end - see attached photo.
                      Gary
                      NCRS Texas Chapter
                      • David L.
                        • July 31, 1980
                        • 3310
                        Gary
                        [ATTACH=CONFIG]69622[/ATTACH]
                        Gary,
                        There were two different manufacturers of 1958 Chevrolet dipsticks. I have both types as shown in my previous photos.
                        Were there two different manufacturers of Early 1956 Corvette dipsticks or just one?
                        Dave
                        • Gary C.
                          Administrator
                          • October 1, 1982
                          • 17771
                          Dave,
                          AFAIK there was a single source for the 56-7 Production installed dipsticks.
                          Gary
                          NCRS Texas Chapter
                            • 43248
                            Originally posted by David Liukkonen (3775)
                            Gary,
                            Dave
                            Dave------
                            Even if the early 1956 Corvette dipstick was used for some MD/HD truck applications, which is likely, I would think the PRODUCTION requirement would have been so low it's hard to imagine that 2 suppliers would have been involved in manufacturing them.
                            • David L.
                              • July 31, 1980
                              • 3310
                              I have collected many Chevrolet dipsticks (probably about 50 or more) from the 1950's to the 1970's Chevrolets and there were at least 3 suppliers. In the 1958 there were at least 2 suppliers. Didn't the various Chevrolet assembly plants usually buy from the closest supplier?
                              Dave
