1962 rocker panel trim - NCRS Discussion Boards
  • Dino L.
    • February 1, 1996
    • 694
    Getting ready to install rockers on a freshly painted car, the top edge seems very tight fit into the top of the blind bracket.... Any tricks from the guys that have been to this movie?
    Dino Lanno
  • Terry D.
    • May 31, 1987
    • 2692
    Re: 1962 rocker panel trim
    Are both sides the same as far as how tight they are? Mine was actually a little loose so I had to bend the bracket a little. Maybe your bracket is bent the other way.
    • Wally A.
      • May 31, 1979
      • 170
      to tight, place flat washer between body panel and bracket. quick and easy
      • Dino L.
        • February 1, 1996
        • 694
        I tried the washer trick, it sticks out and you can see the washer, looks obvious
        Dino Lanno
