Bought an all original 60' in the fall, finally got it out over the last few weekends and at first the temp gauge was running at 180/185 drove 50 miles no issues, checked with laser gun seemed real close!!
Only problem generator wasn't working, so I removed the generator diagnosied that the armature was bad, installed an original I had that was rewound, started the car yesterday, charging perfect ,after all I did was r and r the generator and with in five minutes the car was at 200/220 on the gauge
i used the laser thermostats/radiator are at 170/180 at idle or going down the road!!
So I guess my question is are there any resisters in the dash or any thing else that could trigger this issue all of a sudden??
As nothing else was touched!!
I checked all the wiring for chaffing, checked the wiring with an ohm meter and nothing grounded, all connections are tight etc, I installed a known good original GM sending unit, exactly the same results, so I'm thinking the gauge but before I touch anything I wanted some opinions if I was missing something be fore touching an all original car
Any help or thoughts would be much appreciated!
Thanks in advance
Thanks in advance
