327 oil pan bolt size - NCRS Discussion Boards
  • Richard S.
    • April 1, 2003
    • 288
    I am trying to find out the bolt size/length of the 18 pcs that hold the oil pan to the engine block.
  • Michael G.
    • November 12, 2008
    • 2157
    Re: 327 oil pan bolt size
    14 of them are 1/4-20 x .50" long, the 4 on the ends are 5/16-18 x .56" long.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Richard S.
      • April 1, 2003
      • 288
      Thank you for the detail. I snapped one off and looking for one without buying a set.
      Thanks again.
      Rich
      • John D.
        • December 1, 1979
        • 5507
        I always remember that the oil pan corner bolts are
        5/16-18 x 9/16. Some of them are recessed hex bolt with a free spinning split lick washer. Some have aB&H logo with a circle around them and are quite similiar to the big buck '57-58 B&H bolts that hold the fuel filter bracket to the cannister. Except the thread on the original cannisters is fine thread. So bubbas like me will run a 5/16-24 die over the course thread and use them as real deal for the fuel filter. If you really know what you are looking at the circle around the B&H is not as it should be. Trivia for the day. JD
        • David L.
          • July 31, 1980
          • 3310
          I would say that the 1/4"-20 oil pan bolts are the same as those on the timing cover.
          • Michael G.
            • November 12, 2008
            • 2157
            Rich, I'd send you the one in the pic, but the shipping would cost more than a set of bolts
            Mike
            • Richard S.
              • April 1, 2003
              • 288
              Thank you for the information
              • Richard S.
                • April 1, 2003
                • 288
                You are correct I may need to buy a set. But the good side of this is I was able to get the old broken screw out thanks to the locator punch set I just purchased from McMaster Carr.
                Rich
                  • 43247
                  Rich
                  Rich-------
                  The thing that causes these bolts to break is the application of too much torque. The GM spec for the torque is 80 lb/inches for the 1/4" bolts and 65 lb/inches for the 5/16" bolts. (I don't know why the torque is less for the larger bolts but that's the spec). The bolts will actually take somewhat higher torque than this without a problem and you may find that you need to use a bit higher torque to prevent/cure any leaks. However, they won't take "gorilla" torque.
                  • Richard S.
                    • April 1, 2003
                    • 288
                    Rich-------
                    I agree with the torque issue
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      I just installed a very nice Fel Pro one piece pan gasket. The instructions say torque the 1/4" bolts to 8 ft/lb and the larger ones to 20 ft/lb.
                      Much to high in my opinion, so I did not use the specs.
                      Bruce B
                      • Gary B.
                        • February 1, 1997
                        • 7053
                        Bruce,
                        All I can say is wow about the Fel Pro torque specs. For the 5/16 bolts the Fel Pro value of 20 ft-lbs = 240 in-lbs. Not close to Joe's value of 65 in-lbs. Who can you trust these days???
                        Gary
                        • Jimmy P.
                          • June 24, 2014
                          • 1696
                          Bruce B
                          Bruce,
                          Did you use your original bolts with the Fel Pro or the bolts that came with the gasket? The bolts that come with the gasket are a little longer. Maybe that's why the torque spec is different? I just installed one on my 73 SB but I didn't try my original bolts because I was worried I'd have a leak. I didn't follow that torque spec either.That gasket sure is nice to work with isn't it? Let me know if you used your OEM bolts and I'll put mine back on. I have no leaks so far
                          Jimmy
                          Jimmy
                          1973 Convertible
                          L48,M20,N40
                          Mille Miglia Red/Oxblood
                          • Bruce B.
                            • May 31, 1996
                            • 2930
                            Gary,
                            I agree with you.
                            I will email Fel Pro when I get time and question their numbers.
                            BTY I got a in/lb ancient Kent Moore torque wrench from a friend who never used it, so I will see how it works
                            Bruce B
