68 exhaust tips - NCRS Discussion Boards
68 exhaust tips
  • Cliff K.
    Infrequent User
    • November 1, 2003
    • 20
    68 exhaust tips
    How many slots were in original exhaust tips (GM calls them 'SPOUTS' in the parts books) for 68? Two or four? Does this change for later C-3's? Thank yo.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 68 exhaust tips
    Is this a trick question? Four, there are two on each tip. And I do not recall there being any positional relationship to the angled cut nor the weld seam. But the slots are 180 degrees apart.
    • Cliff K.
      Infrequent User
      • November 1, 2003
      • 20
      Re: 68 exhaust tips
      Not intended to be a trick question. After thinking about you answer, I could have been more specific. I was referring to one exhaust tip, not a pair of tips.
      Attached are pics of what purports to be original survivor tips (two slots) and what purports to be correct GM replacement (4 slots).
      If I understand your answer correctly, you are saying the two slots per exhaust tip is original factory correct?
      Thank you,
      Cliff
      • Cliff K.
        Infrequent User
        • November 1, 2003
        • 20
        Re: 68 exhaust tips
        The other question I have is in regards to the dimensions of 10-5/8 on the top side and 8-00 on the bottom side that is shown in the Judging Manual. All of the exhausts tips I have been able to find are about one-half inch short of this specification. Is the judging guide correct and is this dimension set in stone?
          • 43247
          Re: 68 exhaust tips
          Cliff------
          The original tailpipes (this is the only term I have seen in GM P&A catalogs) had TWO slits.
          By the way, this style tailpipe was used for only 2 model years----1968 and 1969. While similar, the 1968 and 1969 were different.
          The tailpipes with 4 slits were NEVER originally used on a Corvette. These tailpipes, GM #496346, were originally used on some Oldsmobile and Pontiac models. They became SERVICE for 68-69 Corvette applications after the original parts were discontinued. They actually differ from the original Corvette tailpipes in ways other than the slit difference. It's not a pronounced difference, but there's a difference.
