65 PCV valve - NCRS Discussion Boards
65 PCV valve
  • John C.
    • December 30, 2010
    • 204
    65 PCV valve
    I searched the archives and had no luck. Trying to sort out the few things that are incorrect on my 65 300/327. Long Island's site doesn't show a PCV valve for this engine, only a restrictor at the rear of the carter carb. Does the 300/327 not have a PCV valve ?
    JC
  • Jim D.
    • 2885
    Re: 65 PCV valve
    That is correct.
    • Gene M.
      • April 1, 1985
      • 4232
      Re: 65 PCV valve
      The fitting at the rear base of the carb has a small hole in it that "meters the vacuum leak" causing a small negative pressure to the crank case.
      • John C.
        • December 30, 2010
        • 204
        Re: 65 PCV valve
        One would think that would be enough to cause a vacuum leak, but I guess not since there are plenty of them out there that run fine. Thx Guys !
        JC
        • Timothy B.
          • April 30, 1983
          • 5195
          Re: 65 PCV valve
          John,
          It is a vacuum leak, it's just calibrated in that the carburetor metering A/F ratio takes that into account. FWIW, are you having problems with the AFB idle.
          • John C.
            • December 30, 2010
            • 204
            Re: 65 PCV valve
            Not really. But, even though most of the car is original unrestored, it did have an incorrect carb. I've got it torn down, so-to-speak ready for a dewitt's 941, manifold with new fresh air tube and a few other new goodies. I'll actually get the restored 3721 AFB (correctly dated ) back from Carb Junky's today and will be able to put it all back together. If I do have any issues I'll sure 'nuff give you a shout.
            Thx for the assistance,
            JC
