Shifter Rods Rust Prevention - NCRS Discussion Boards
  • Greg K.
    • September 30, 1985
    • 32
    Does anyone have any good product(s) for preventing rust from forming on bare steel shifter rods? I don't want to paint or plate them. I would assume some sort of oil would be best, but wondering if anyone has something specific that works well.
    • 15667
    Re: Shifter Rods Rust Prevention
    Armor-All or WD-40 should help as long as they don't see much water splash.
    • Jerry G.
      • February 1, 1989
      • 226
      I use Ultra Lube spray lubricant that I bought at Home Depot. It's non toxic, soy bean oil. I used it for exactly what you're doing months ago and it's still looks like the day I did it.
      • Bill L.
        • February 1, 2004
        • 1403
        RPM - Rust Prevention Magic.
        Bill
        • Joel A.
          • September 30, 1997
          • 213
          I used ZEP45 on all my bare metal stuff when I did the '74 years ago('99-2000). Drive/half shafts, yokes, shift rods, etc. No rust on any of it to this day, and it has been driven in the rain a few times since.
          Joel Adams
          1974 Coupe
          1985 Coupe
          "I know the voices aren't real...but sometimes they have some really kewl ideas...."
          • Paul S.
            • October 29, 2014
            • 16
            Try ACF-50 by Lear Chemical, they use this stuff to fog inside airplane wings so nothing corrodes when the plane goes from high altitude to ground level.
            • William F.
              • June 9, 2009
              • 1363
              Are rpm, ZEP 45 or ACF-50 visible when applied or remain oily, greasy and attract dirt?
              • Greg K.
                • 32
                I have found another product that looks to be promising as well. It's called Gibbs Brand Lubricant that cleans rust and prevents. It dries clear without an oily or sticky finish and has the feel of the bare metal. It comes in spray and liquid form. RPM is similar except it is a paste and must be brushed on warm metal. RPM also does not clean existing rust. RPM does dry clear with a non-oily and non-sticky finish. Not sure about ZEP 45 or ACF-50. Doing some research on those two.
                • Michael G.
                  • November 12, 2008
                  • 2157
                  Try Froglube CLP, get it on Amazon or at a gun shop. Its colorless, lubricates extremely well, doesn't damage anything, and is better than almost anything you can apply by hand at preventing rust.
                  Mike
                  1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
                  1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
                  • Donald H.
                    • November 2, 2009
                    • 2580
                    I used RPM on everything of bare metal when I put my 66 chassis together in October/November.
                    Most of the parts already have some spots of surface rust. The chassis has not been outside at all.
                    I closely followed the instructions.
                    I am very disappointed in this product.
                    Don Harris
                    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                    • Joel A.
                      • 213
                      ZEP 45 is a spray lubricant. It does stay a little wet for a while, and yes, it will get some dust bunnies on it....but it can be wiped, and still protect. After 10-12 years of mine being done, I have only MINOR surface rust in a couple of spots on the half-shafts...but that also wipes right off. For maintenance, I spray some on a rag, and wipe the parts. My car sits for years, but at least it's not rusting to the ground. I also used it on my front springs, ball joint rivets, etc. Works well for me, and have not had any deductions for any of those parts.
                      Joel Adams
                      1974 Coupe
                      1985 Coupe
                      • William F.
                        • June 9, 2009
                        • 1363
                        I drive mine. Don't want to collect dust.
                        • Greg K.
                          • 32
                          It's been a few years now and I have been using the Gibbs Brand Lubricant on many of my parts without any rust forming on the bare metal. Back in 2016, I cleaned a set of 3 speed shift rods to the bare metal. I treated the rods with the Gibbs Brand Lubricant and they sat in my garage for 4 years and the last 3 years they have been in my basement. They still look like the day I coated them with the lubricant. The lubricant dries with no oily residue and has a slight sheen. Otherwise, it looks and feels just like the bare metal. Have not tried the RPM or ZEP 45 or ACF-50 lubricants.
