Flattening oil pan rail holes - NCRS Discussion Boards
  • Larry M.
    • December 1, 1986
    • 541
    I used this method to flatten the bolt holes on the oil pan rail - I had a piece of square tube stock that fit within the width of the rail, and then used a c-clamp to press the holes flat. I was very pleased with the results -
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Flattening oil pan rail holes
    I do pretty much the same with steel bar but I tap the holes with a small hammer. Backing up the bar against wood sitting on the bench. Achieves the same results. Good tip.
    • Steven B.
      • April 11, 2012
      • 233
      I've found a general purpose dolly will fit the underside of the rail allowing a couple taps with a finish/pick hammer. Generally the same setup but it's very easy to move the dolly.
      • Mike M.
        • May 31, 1974
        • 8383
        i have an ancient blacksmiths anvil i use in place of a dolly. a modified body hammer ,who width is less than the "trough" , will allow flattening of the concave depressions in the "trough". i probably use the anvil at least daily. suggest you all pick one up at the local flea market/swap meet. invaluable little critters. mike
