1963 shp - NCRS Discussion Boards
1963 shp
  • Jerry C.
    • November 1, 1995
    • 741
    1963 shp
    Water pump bolts that bolt pump to block, lock washers or not as the kit did not include lock washers. Thanks in advance.
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 1963 shp
    Jerry,
    Here's a 63 340HP that might answer some questions you have.
    Nice 340 undergoing restoration. Ignore the blue silicone sealant.
    • Michael G.
      • November 12, 2008
      • 2158
      Re: 1963 shp
      I believe there are no washers on bolt in the passenger side lower water pump hole, as well as the driver's side upper water pump bolt, though I've seem there on some cars. The stud that attaches the pump through the lower passenger side hole also does not have a washer against the pump. The alternator brace bolt, that passes through the upper passenger side pump mounting hole, does have a lock washer under the head of the bolt. The idler nut has a flat washer and a lock washer under the nut.
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
        • 43277
        Re: 1963 shp
        Originally posted by Michael Garver (49693)
        I believe there are no washers on the passenger side lower water pump hole, as well as the driver's side upper water pump bolts. The stud that attaches the pump through the lower passenger side hole also does not have a washer against the pump. The alternator brace bolt, that passes through the upper passenger side pump mounting hole, does have a lock washer. The idler nut has a flat washer and a lock washer.
        Mike------
        Correct.
