Searched the archives and didn't see anything ...
When radio is installed in car am band only has static. FM works fine. Had radio checked on a bench and both bands work. Obviously this points to the antenna. Looking for advise on where to look before I just replace everything. Any measurements I can take to determine if it's the cable, the antenna base etc ?
Thanks !
Thanks !
I 've driven the car many times and it's been fine. I told Jerry what it was doing and he was very willing to look at it again to see if there was an issue in the radio where the antenna cable plugs in. But, I did not want to go through the difficult job of removing the radio. I'm satisfied, it's working fine. Just another option for you to try before you take out the radio.
