1969 heater box vacuum actuator - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    Hello, my 69 non ac heater distribution box has 2 vacuum actuators.... On on top of the box which I think diverts air through the heater core, and another larger one which I think works the defrost. Does anyone know part numbers for these? Can't find them in the AIM. Thanks
    • 43277
    Re: 1969 heater box vacuum actuator
    Roger-----
    Believe it or not, this is a tough question. The actuator part numbers are not shown in the AIM because, I believe, they were supplied to PRODUCTION as part of the heater box assembly. Information on these actuators is somewhat sketchy in the P&A catalogs.
    However, I believe one of the actuators was GM #1998955. This actuator is long-since GM-discontinued and quite difficult to find in NOS condition.
    The other actuator MAY have been originally GM #1996603 and, later, GM #1996686. The latter is still available from GM or Delco. The "sketchy" part of this is that GM says this actuator was used for Corvettes equipped with A/C. However, they never cataloged another actuator for non A/C models. So, was it the same for both? I don't know, for sure.
    • Roger G.
      • October 11, 2012
      • 268
      Joe, thanks for the info, Roger
      • Roger G.
        • October 11, 2012
        • 268
        FWIW, Here is the hot air actuator15250B73-74D9-4B56-A841-C2490CD2284F_zpsonihyhuy.jpgB65B0C3C-D521-41E0-B724-94AFE2DFD562_zpsyznwscc8.jpg
        and here is the defrost actuatorE1C906A1-433B-4054-939E-8DAFDBDD6B75_zpswsyg22q9.jpg475D1F18-63D9-469B-B2C9-9F5B0784CB6D_zpsbwd8bvh3.jpg
          • 43277
          FWIW, Here is the hot air actuator[ATTACH=CONFIG]69194[/ATTACH][ATTACH=CONFIG]69193[/ATTACH]
          and here is the defrost actuator[ATTACH=CONFIG]69196[/ATTACH][ATTACH=CONFIG]69195[/ATTACH]
          [ATTACH=CONFIG]69197[/ATTACH]
          Roger------
          Very helpful information!
          The large actuator was originally GM #1998963 (that's what the "963" denotes on the lever). It was discontinued in April, 1971 and replaced by GM #1998955. The latter was discontinued quite some time ago. However, Old Air Products offers a functional replacement for this actuator.
          The smaller actuator is obviously GM #1998962 as stamped on the lever. This actuator was discontinued in December, 1971 and replaced by GM #1998948 which is also long-since GM-discontinued.
          Are you sure that you need either actuator? These actuators are very easy to test. Simply apply a vacuum source to the nipple on the actuator and observe if the lever moves.
          • Roger G.
            • October 11, 2012
            • 268
            Hello Joe. The small one is good, but the big one is bad on one side. I sourced a Delco 1998999 that looks just like it, but the actuators are at right angles. Original is on right
            These look like they are pinned on, so I may be able to jury rig the old connector on the the new one
            The box is such a PITA to take apart, with all the rivets that need to come out, that I thought it would be a good idea to replace them now, along with all the seals. I don't want to do this again. Old Air is in FW, so I may give them a call.
