C-3 Headlight rubber boots - NCRS Discussion Boards
  • Rey S.
    • April 1, 1995
    • 277
    My vehicle is not yet complete enough to be drivable or even started up. I have notice that my headlight operating diaphragm rubber link shields have depleted them self's to the point that they are falling apart, mine are only 2 years old ( they have been cycled periodically and not exposed to weather). Is this a normal situation requiring replacement every few years? Is there anything that will prolong their life(other than converting to electric operators) as it's a pain in the "you know what" to replace them?
    Thanks -- Rey S.
    • 43202
    Re: C-3 Headlight rubber boots
    Thanks -- Rey S.
    Rey-------
    One of the actuators, including boot, on my original owner 1969 is original to the car and is in perfect condition after 47 years.
    • Bob D.
      NCRS Shipping Data Report Manager
      • April 30, 1996
      • 787
      Rey
      Living in a dry climate will help to dry the rubber out and make it brittle. They also rub against themselves when cycling in and out and this can cause a failure. One way to help is to cost them with a silicone grease. This will prevent the boot from rubbing and causing a failure.
      Bob
      • Rey S.
        • April 1, 1995
        • 277
        Thanks Bob
        I will incorporate this fix when I get around to changing them. Coat the inside as well ? I will also do the wiper door actuator !
        Rey
        • Bob D.
          • April 30, 1996
          • 787
          Rey
          Yes I coat them inside and out.
          Bob
