C3 dual exhaust leak - NCRS Discussion Boards
  • Ross F.
    • August 31, 2004
    • 167
    The exhaust joint that is clamped to the u shaped hanger attached to the Trans and crossmember is leaking at the top.
    i have adjusted and wiggled and I can't get a tight seal. Any suggestions?
    • 43273
    Re: C3 dual exhaust leak
    Ross------
    You must get it adjusted so there is no "gap" anywhere in the 360 degrees of the rear pipe slip joint. If there is a "gap", there will be a leak.
    • Russ S.
      • April 30, 1982
      • 2163
      Use a high temp sealant before putting it together.
        • 11692
        Agreed. You can - and should - use sealer here. It's readily available at any auto parts store.
        If you look in the AIM, the factory used it too.
        • Ross F.
          • August 31, 2004
          • 167
          Thanks for the responses. But I have torqued down on the clamp to the point that pulling the joint apart proves futile. Can I heat the otter pipe and expand it so I can slip it apart? As the pipe passes through the the frame right there it is hard to work the joint free.
          am I hosed and should just cut the mid pipe off ant start over?
            • 11692
            I've thought that before, yet gotten it apart.
            They do make tools that will help force apart the exhaust. IIRC you can rent/borrow them at AutoZone and similar places.
