I'm ready to reinstall the 024 distributor back into a 340 hp engine after resealing a leaky intake manifold and rebuilding the carburetor, etc.
I did some baseline tests before disassembly and checked timing, etc. It's spec is 12*, but I measured apx 14* on my timing light at idle, apx 750rpm. There is no detonation or unusual behavior under load, except for a slight stumble.(I found the accelerator pump screws loose on rebuild so I think that may be solved).
This engine has ported vacuum. I had it idling for about 20 minutes the other day and it ran fine and cool at 180*. The vacuum can was about 1/8" away from the stock intake, and the plug wires were indexed properly. I would like to get the vac can better positioned and also to ease the strain on the tach cable. I also tested the MS 201 15 vac and it was right at spec, starts at 8" and all in at 15".
The dimple on the gear does NOT align with the rotor tip. This engine is very original but I'm unsure if the distributor was ever out. it has a split pin in the gear.
Rotating the gear to line up the dimple to the rotor tip will do exactly what in this situation? Will I make matters worse by rotating the gear?
at rotor tip, no dimple.
away from rotor tip, dimple.
Rich
Rich
