I'm trying to install my new windshield with new rubber gasket on my '67 coupe.
I was not successful last Saturday using the rope trick.
My question is, should I try to install the bottom gasket into the metal bird cage lip first (which I did) or
should I try to position the glass with rubber gasket installed evenly into the opening (between the trim clips) and then try pulling the rope with someone outside "gently" pushing the glass?
