63 Outer heater box Question - NCRS Discussion Boards
    • 6948
    At some point during the 63 model GM started reinforcing the outer heater box at the hose outlet area. Does anyone know about when this started?? Thanks, Ed
    • 6948
    Re: 63 Outer heater box Question
    I thought I would put this post to the top, was hoping some of you early 63 would go out to garage and take a peek at what your Corvette has for the outer heater box, Thanks, Ed
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11329
      Ed, What exactly are these reinforcements? Do you have a photo of each type?
      Rich
      • Richard H.
        • March 1, 1995
        • 45
        Here is my early '63 #1318:
        http://
        • Harry S.
          • July 31, 2002
          • 5330
          Ed, April 20th car 133XX has no support.
          I do have a spare, the ink stamp inside the box is April 1_ 63. Could be the 1st or 11th - 19th. This one does have the support. I do not know the VIN it came from. I didn't look at the A/C car.
          I would make the assumption the change started sometime in late April or whenever old stock was depleted.
          • Rich Y.
            Infrequent User
            • April 1, 2012
            • 24
            Here is a photo of my car #8967.
            • Mike L.
              • January 1, 1986
              • 312
              Car # 105 has NO support.
                • 6948
                Rich
                Rich, the photo on the right shows a raised rib at the right of the hose outlet. hope this helps. the left picture is a earlier Dec. 62 the one on the right is a later Feb. 63
                  • 6948
                  Guys, thanks for the replys. I Just today cleaned up the original heater cover and found a date (Feb.7, ) on the inside of the housing, Which has a the reinforcement at heater tube outlet, So I guess my March car is considered a mid/ late production, As is Richards car.
