94 corvette coupe door locks - NCRS Discussion Boards
  • Eddie R.
    • February 27, 2012
    • 22
    Hi. I have a 1994 corvette coupe that I have almost completely restored. I am having a problem with the door locks. When I started this process the door locks worked. Now they don't. The only way to lock the doors is with the key. I do not have the remote so I have to manually open and lock the doors. When I push on the lock button nothing happens. I replaced the lock switch but that has done no good. Neither passenger or driver door lock is working so I'm thinking it might be something as easy as a fuse. I checked the book and the only fuse for locks listed was for the remote. That fuse was fine. Is there another fuse that I should be looking at? Any other ideas as to what the problem may be? Thanks for your help. I really appreciate it. Thanks Eddie Robin
  • Kenneth P.
    • November 17, 2015
    • 151
    Re: 94 corvette coupe door locks
    Check the keyless entry receiver module to make sure nothing got unplugged while you were working on it.
    Ken
    • Kenneth P.
      • November 17, 2015
      • 151
      Ken
