Pulling an Engine - NCRS Discussion Boards
Pulling an Engine
  • Terry D.
    • May 31, 1987
    • 2697
    Pulling an Engine
    Getting ready to pull a small block chevy with vortec heads. Not a fan of the carb plate to pull motors, always used the intake bolts, or exhaust bolts, but on this vortec head engine the intake bolts aren't any bigger then the carb bolts. Has anyone done this using the intake bolts? Any and all suggestions appreciated.
  • Jim S.
    • March 1, 1986
    • 1408
    Re: Pulling an Engine
    Terry,
    Like you I never liked the idea of using the carb plate, especially on an aluminum intake . My neighbor however , a long time car guy , told me he has done dozens of motors this way with no ill effect. So that's how I pulled and replaced mine . Also apparently with no ill effect, for what it's worth .
    TWO-TON ENGINE HOIST:
    A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
    Jim
    • Chris S.
      • January 1, 2000
      • 1068
      I have installed and removed dozens of engines with a carb plate
      I use grade 8 hardware and oversize washers to spread the load.
      a SBC weighes around 550 pounds give or take
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Terry D.
        • May 31, 1987
        • 2697
        Another reason I don't like the carb plate is when pulling the motor with tranny still attached (as is the case here) how do you keep the whole thing level? I have always used a load leveler.
        • Jim D.
          • 2885
          No way would I trust a SB or especially a BB being suspended by 4 - 1/4" studs in aluminum. Like Terry just pointed out, you can't use a leveler either.
          • Pat H.
            • December 1, 1996
            • 420
            When removing the engine from my 59, I used grade 5 bolts and attached the chains to each corner of the engine. The exhaust manifolds were removed. I did the reverse when it was installed
            • Robert D.
              • April 1, 2003
              • 305
              The amazing thing is a grade 8 1/4 inch bolt has a tensile strength of over 4 thousand pounds so theoretically one bolt can support the engine now im not advocating that but it amazes me how strong theses things actually are. I suppose the limiting factor is the aluminum manifold does anyone have tensile stregnths or how much force it takes to pull out a 1/4 inch bolt in the type of aluminum our manifolds are made of? just food for thought i dont particularly like lifting motors from the carb studs either but my best friend owns a garage and hes done hundreds like that with no problem.
              • David G.
                • May 31, 1980
                • 275
                I have removed and installed dozens of engines using the intake carburetor studs and never had and issue. You can use a leveler bolted directly to the plate to tilt the engine during installation. Very slick and easy.
                  • 43263
                  Robert------
                  Carb studs are 5/16-18 thread size.
                    • 43263
                    Terry-------
                    1) Use 5/16-18 grade 5 or 8 studs that FULLY THREAD into the manifold;
                    2) Install carb plate;
                    3) Install 2 hardened flat washers on each stud;
                    4) Install grade 5 or grade 8 hex nuts and torque to 20 lb/ft
                    The above will easily support ANY engine you're going to install in a Corvette whether the intake manifold is cast iron OR aluminum.
                    • Robert D.
                      • April 1, 2003
                      • 305
                      oops thanx for the correction that only makes them stronger
                      thanx
                      bob
                      • Terry D.
                        • May 31, 1987
                        • 2697
                        Thanks everyone but we found the vortec heads have screw holes on the end that take a much larger bolt, the owner felt much better, plus I still don't see how you can attach a leveler to a carb plate? At least not the leveler I have! How about a picture or description of the Dave?
                        • David G.
                          • May 31, 1980
                          • 275
                          [QUOTE=Terry Deusterman (11486);768977]Thanks everyone but we found the vortec heads have screw holes on the end that take a much larger bolt, the owner felt much better, plus I still don't see how you can attach a leveler to a carb plate? At least not the leveler I have! How about a picture or description of the Dave? Terry, I have my engine leveler lent out now, But the leveler in an inexpensive harbor freight tool. I cut 2 pieces of 1/4 inch steel about 3x5 inches. I drilled 2 holes in the plates and welded one to the lower part of the leveler and sandwich the carb lift plate between the welded plate and the other plate. 1/2 bolts are used to bolt through the first plate, then the carb lift fixture, then the other loose plate. It really is easier than this description. If I had it here, I would provide photo. BTW I also remove the hand crank and weld on a 1/2 inch nut for easier tilting.
                          Dave
                          • Terry D.
                            • May 31, 1987
                            • 2697
                            Dave
                            When you get it back please e-mail pictures, am real curious to see this set up
                            PS you have a private message
                            • Wally A.
                              • May 31, 1979
                              • 170
                              since when are intake carb bolts 1/4" all 5/16 ive ever seen, and the will hold
