Correct M-20 Part Number Tag/L48? - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1696
    What would the correct part number be on the Muncie M-20 tag bolted to the tranny? My 1973 engine is an L-48.
    Thank you.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • 43247
    Re: Correct M-20 Part Number Tag/L48?
    Originally posted by Jimmy Patitucci (60161)
    What would the correct part number be on the Muncie M-20 tag bolted to the tranny? My engine is an L-48.
    Thank you.
    Jimmy------
    6271518
    • Jimmy P.
      • June 24, 2014
      • 1696
      Thank you Joe
      Jimmy
      1973 Convertible
      L48,M20,N40
      • Jimmy P.
        • June 24, 2014
        • 1696
        Joe,
        Do you know for sure if the 73's had the tag on the tranny? Everything that I've been able to find in the archives and online stops at 72 using the part number you list above. They also had two letter broadcast code following the numbers. The 73-74 JG says there should be one present, but that might be a carry over from 1972.
        Thank you!
        Jimmy
        1973 Convertible
        L48,M20,N40
          • 43247
          Joe,
          Thank you!
          Jimmy------
          I can't say for sure but I'd be surprised if 1973's didn't have a tag. The part number I mentioned could not have been used prior to 1972.
