327 1965 drain block - NCRS Discussion Boards
  • Robert Y.
    • November 4, 2015
    • 9
    How is the water drained from the block on a 327 engine?
  • Timothy B.
    • April 30, 1983
    • 5188
    Re: 327 1965 drain block
    Robert, There is a 1/4" pipe plug on each side of the block that allows complete draining of all coolant. The plugs are located approx midway on the block sides and about the level of the bottom of the freeze plugs.
    This in addition to the radiator drain will empty the system.
    • Robert Y.
      • November 4, 2015
      • 9
      Timothy, thanks so much, this helps!
      Bob
        • 43229
        Bob
        Bob-------
        Be aware that these block drain plugs can be extremely difficult to remove. Every now-and-then folks crack a block trying to remove one.
        • Robert Y.
          • November 4, 2015
          • 9
          Joe, thanks for the warning. I will proceed carefully.
          Bob
          • Jim T.
            • March 1, 1993
            • 5351
            6 point socket is the best to use
            • Phillip M.
              • September 30, 2006
              • 100
              I removed the drain plug in my '67 327 last fall, and I can safely say that it was the most difficult drain plug that I ever encountered. As stated previously, use only a 6-point socket. I did not use WD-40, but may help after a couple days soak. I used a 1/2" drive flex handle with a piece of 1 ft. long pipe to increase leverage. Attacked the bolts from the top after removing shielding and exhaust manifolds (I was prepping the engine for a head swap anyway). With all of the above giving me a clear shot I had to lean all my weight into the wrench handle before they slowly gave way. These are iron plugs and at that the hex was pretty chewed up by the time I was done with them. Makes you wonder why they were installed as tight as they were.
              Phil
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11325
                I suggest you use CRC Freeze-Off on the drain plugs. It will slightly shrink the plug and may help loosen it.
                It's messy and smelly, so use a big old rag or towel nearby when you spray it all around the plug. Use eye protection as well.
                I have used this product many times with great results.
                • Don H.
                  • December 1, 1981
                  • 1487
                  One more thing, it is common for the "crud" inside the block to be so thick that nothing comes out when the plug is removed. If so take a screwdriver to punch through and the coolant will start to flow. Good luck, Don H.
                    • 43229
                    Phil
                    Phil-------
                    It's not that they were originally installed with high torque, it's the corrosion that occurs over the years. If someone had tried to remove them when the car was new, it would have been easy. 50 years later, not so easy.
                    • Robert Y.
                      • November 4, 2015
                      • 9
                      Thanks for the help; the plugs came out with a 6-point socket without a lot of force.
                      • Bert L.
                        • April 30, 1977
                        • 427
                        You were very lucky Robert,.....
