Need picture of correct 1967 alternator L79 HT (fan and pulley) - NCRS Discussion Boards
  • Keith B.
    • December 1, 1991
    • 398
    I would appreciate if someone could post picture of the fan and pulley for a 1967 327 350 hp (HT) alternator fan and pulley that is correct for judging. I have two different styles and want to make sure i send the correct pair to the restorer. Are there part numbers anywhere that I can see? The judging manual has part numbers referenced. This car has the 693 37 amp (no air conditioning)
    Keith Burmeister
  • David L.
    • July 31, 1980
    • 3310
    Re: Need picture of correct 1967 alternator L79 HT (fan and pulley)
    Keith,
    The part numbers for the 1967 327 w/SHP are as follows:
    alternator pulley 3829387
    alternator fan 3843346
    The fan-pulley part number for the 1967 327 wo/SHP & wo/AC is 3909815.
    Enclosed is a photo of an original 3829387 pulley and a 3843346 fan. The pulley has the stamped part number "3829387 AI" but the 11-blade fan does not have a stamped part number.
    Dave
    • David L.
      • July 31, 1980
      • 3310
      Here ia a photo of an original 1967 327 base engine alternator 11-blade fan-pulley stamped "3909815 AJ".
        • 43288
        Originally posted by David Liukkonen (3775)
        Keith,
        Dave
        David and Keith-------
        This pulley is available in reproduction and the reproductions are excellent. As far as I know, the fan is not available in reproduction. However, there should be lots of these out there for the "picking". This fan was by no means unique to your application-----usage was very wide-spread.
