67 TI distributor - NCRS Discussion Boards
67 TI distributor
  • Robert D.
    • April 1, 2003
    • 305
    67 TI distributor
    can someone give me the part number for the main shaft in a 67 TI distributor 1111258? are all the shafts same if not what are the differences
    thanx
    Bob
    • 43212
    Re: 67 TI distributor
    thanx
    Bob
    Bob------
    The part number for the main shaft for your application was GM #1969058. This piece was GM-discontinued without supersession in 1980. Your chances of finding an NOS example 36 years later are slim-to-none.
    All of the Corvette distributor mainshafts were not the same. However, the primary difference was the auto cam brazed to the top of the shaft. There were numerous configurations of these and the configuration is important to achieving the correct mechanical advance. If you have an original shaft, you can have the original auto-cam removed and brazed onto a new shaft which is available in reproduction. The other alternative is to use a shaft with a generic auto-cam and have the distributor set up with a distributor machine to achieve the original mechanical advance specs.
    • Robert D.
      • April 1, 2003
      • 305
      Thanx Joe
      i do have an original one so i will take that route
      bob
