Grand Sport Replica with T.I - NCRS Discussion Boards
  • Larry T.
    • February 1, 1990
    • 29
    I am assembling a 63' Grand Sport replica with old school TI. I know not all distributors are the same, so the question is a 377 ci with crossram webers and 11:1. Which 64-71 distributor would be the best fit so I can spend my 401k on it???
    • 15706
    Re: Grand Sport Replica with T.I
    It depends on the camshaft design. If you have a high overlap cam with a late closing inlet valve, the 365/375 HP spark advance map would be a good starting point, but it may be difficult to run a VAC with an IR manifold.
    Any single point or TI distributor can be tailored to the specific configuration with suitable weights, springs, and VAC.
    • Larry T.
      • February 1, 1990
      • 29
      Thanks Duke
      Jim inglese is doing the Weber set up and stated he will send me the perfect cam info, so I will hold off on distributor choice till then.
      Larry
