67 big block Dewitt Radiator - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    How many points does one lose for not having the original or original reproduction radiator? I see a lot of cars having the dewitt aluminum radiator. I'm doing a frame of restoration on my 67' 427 390hp and wondering if it is worth the effort of using my original radiator. I was looking at a Dewitt Aluminum model # 1239066M. Does anyone have any experience with this particular radiator?
  • Gary J.
    • April 1, 1980
    • 1244
    Re: 67 big block Dewitt Radiator
    No experience myself, but on the score sheet it is 15 pts.for originality and 10 points for originality for radiator and mounting so I would figure about 12 points on originality and 8 points on condition, for the radiator only, as long as you use the original mounting hardware. If not using the original mounting hardware in additional to the radiator it would be a full deduct on the orginality and condition.
      • 11659
      I believe your car originally used a copper/brass radiator, not aluminum.
      Radiator Model: 32-BC67M Complete correct Harrison four row copper brass radiator assembly Features correct channels with square and round holes, cut outs, and dimples Soldered core and end tanks for original appearance Factory-sized inlet and outlet connection locations Fits 1966-1968 Corvette with big block option an
      You could also have your original end tanks used, and have your radiator recored. Note, however, that the upper and lower channels of yours should be re-used, as they have square and rectangular cutouts that the judges will look for. You can just see them on the top of the radiator shown on the DeWitts page.
        • 43246
        Dave------
        The radiator you mention is the DeWitts "Direct Fit" aluminum radiator. It's configuration is quite similar to the original radiator but it's not going to fool any judges. However, painted black, it looks very similar to the original. If you plan to mostly DRIVE the car, I highly recommend this radiator. It will provide about 30% better cooling than the original copper brass radiator used for your application.
        If judging is the most important thing for you, then I'd go with the DeWitts reproduction of the original radiator installed in your car. This is the radiator that Patrick mentions in his post. This is a VERY good reproduction of the original. However, it will only cool as well as the original. Ever hear of anyone with a 1966-68 big block that was unsatisfied with the cooling performance of their cars with original radiators? I have.
        • Rich G.
          • August 31, 2002
          • 1403
          My 68 427/435 runs cool (max 210 in traffic) with the original radiator. The car is completely stock with 38k miles. My radiator end tanks are starting to to develop some pin hole leaks. I know I can probably find somebody to fix it, but for arguments sake, should I expect the De Witts copper/brass replacement to work as well as my original?
          I put a De Witts radiator in my 66 small block several years ago and it's probably the best thing I ever did to that car. It had an incorrect replacement in it when I bought it and it had cooling issues.
          Rich
          • Frank T.
            Infrequent User
            • March 20, 2013
            • 26
            I've used the Dewitt's on a few 67 big blocks with no issues aswell as judging with it no deductions
              • 11659
              Have they added the square and rectangular cutouts in the lower channel?
              When their reproduction first came out it had the cutouts on top but not bottom, and a savvy judge knew to look.
              Patrick
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11333
                Patrick
                This one came from Dewitt's a few months ago.
                IIRC it's mentioned in their description now also.
                • Jim H.
                  • December 15, 2006
                  • 146
                  I have used the DeWitt Direct Fit black ice #1249066M aluminum radiator w/two rows of 1.25" tubes for extra cooling in my 66 427/390. DeWitt claims a 35% improvement over original brass radiator. Cost me about $700 plus shipping. Installation was a breeze (it is direct fit) and the radiator keeps my BB cool. It lacks the rectangular cut-outs of the original radiators, however. Couldn't get the picture to download this morning but will try again later.
                  JCH
                  • Edward S.
                    • December 1, 1986
                    • 514
                    I can tell you this - I had a 65 425 and as I was restoring it I ordered a new DeWitt unit - I had the car for 12 years and took it to Duntov, Triple Crown status without ever losing a point on the radiator. Another big plus was the car always ran 20 degrees cooler then the original. Would highl get a new one in a heartbeat.
                      • 43246
                      Ed------
                      Are you talking about a DeWitt's reproduction radiator or the Direct Fit?
                      • Daniel Y.
                        • September 30, 2002
                        • 185
                        The Brass Radiator for late 66 and 67 big blocks #BC67M is perfect for judging just make sure you tell them holes on the bottom as well as the top.
                        Dan Young
                        65, 67 Duntov x2
                        66 bowtie x 2
                        71 LT1 TF
                        90 ZR1 McCelland
                        03 Anniverary
                        06 Z06
