1966 427/390 no AC battery cable routing - NCRS Discussion Boards
  • Keith M.
    Infrequent User
    • April 30, 2001
    • 27
    need help on positive and neg battery cable routing...first pos,i have the speedo cable in upper clip on firewall and pos cable in lower firewall clip,so what clip holds starter wiring before it goes in spring clip on starter and does pos cable go in spring clip also...I have neg cable under starter bolt plus smaller ground wire from wiring harness) thank you
