C2 Head light opening. - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    Would someone be able to measure the shape of the corners of the headlight door opening for me? If you could tell me what diameter of drill bit matches the shape it would be helpful.
    Thank you,
    Randy
  • Joe R.
    • July 31, 1976
    • 4552
    Re: C2 Head light opening.
    Don't exactly understand the question but then again I am old and slow!
    JR
    • Stephen L.
      • May 31, 1984
      • 3162
      A photo of an original headlight opening. I'll measure later if you need it....
      • Enzo C.
        • January 12, 2012
        • 536
        Here's a pic of my headlight opening and my estimate would be a 3/16 radius...image.jpg
        Enzo Colosimo
        Ncrs Ontario Chapter Chairman 🇨🇦
        ENZ-Z06/67
        • Stephen L.
          • May 31, 1984
          • 3162
          I measured my corner openings using a drill bit. As far as I could tell it appears that a 1/2" drill bit is very close which works out to a 1/4"radius.
          • Enzo C.
            • January 12, 2012
            • 536
            In my pics and observations they varied with in a 1/4"....
            Enzo Colosimo
            ENZ-Z06/67
              • 6960
              Randy, I don't think a drill bit would be a good idea, I would just carefully take a small round file or maybe a Dremel tool to get the desired fit. Steve or Enzo's fit are perfect.
              • Stephen L.
                • May 31, 1984
                • 3162
                I'm not suggesting to use a drill bit to make the cut. I used it as a guide to determine a dimension.
                  • 6960
                  Steve, Sorry I was not trying to imply anything , I was just thinking that randy might be thinking of the drill bit as a tool to get the angles.
                  • Tom A.
                    NCRS Body & Paint Advisor
                    • May 31, 1986
                    • 138
                    I find a 1/2" drill bit is usually right on.
                    • Randy R.
                      • March 1, 1983
                      • 477
                      Thank you for the info.
                      Randy
