1961-1962 Trico Wiper Blade RB-12 - NCRS Discussion Boards
  • Joe M.
    • February 18, 2010
    • 83
    I was looking for some direction on the correct RB-12 Trico blades
    Is it correct the side of the blade insert is embossed with the Patent disclosures in the sidwall of the rubber above the dots?
    Joe
  • Terry D.
    • May 31, 1987
    • 2696
    Re: 1961-1962 Trico Wiper Blade RB-12
    Did you check to see what the new Judging Manual sats?
    • Terry D.
      • May 31, 1987
      • 2696
      Says! Where is spell checker when you need it? My fifth edition says "The non-replaceable rubber inserts have a series of raised dots down each side and a series of patent numbers on one side only. Inserts are 12" long." Hope this helps
      • Gary H.
        • June 30, 1980
        • 155
        Joe I can't see for sure from your photos but you probably should have plastic tips at both ends of the blade. Do some research on that.
        • John S.
          • July 29, 2009
          • 640
          RB-12 replacement blades do not come with the end tips and the receiver is incorrect. RB-12-2 is the box that you find the correct blade with the black tips. even if you have a RB-12-2 you need to look at the receiver. up to 58 there is no rivet on the receiver clip. up to 60 there is a patent number on clip and a small release. 61-62 has no patent number on clip and a long release.
          • Eric E.
            • November 1, 1998
            • 254
            Joe, here is a new nos Trico blade in the box and it shows the orientation of the dots and numbers to the receiver. I be no doubt that this is the way it was assembled the factory. Hope this helps. Eric
