1966 Coupe. Looking for the distance from ground to bottom of fender at centerline of tire. Orville Hunter oshjr@ptd.net.
Body dimension
Re: Body dimension
Orville, there may be some differences from year to year and depending on the tire size, and body shimming and mounting varies because 66 uses rubber mounts. I can tell my 63 is about 26 3/4 with a 760/15 tire.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: Body dimension
Orville,
If you are just need general vehicle height information, the Vehicle Information Kits available from the GM Heritage Center have the ground to center of the headlight distance as part of the AMA specifications. The kits do not have specific fender height information, as stated before the A.I.M. would be the most likely source.
Explore more than a century of innovation, automotive leadership, and iconic vehicles at General Motors—a legacy that still drives the future of the industry.
Once on the GM page, scroll down and select "Corvette". Select the year in question (in your case 1966) and accept the usage agreement. A pdf copy of the Vehicle Information Kit will download. In the case of 1966, the headlight height above the ground is on page 101.Judging Chairman Mid-Way USA (Kansas) Chapter- Top
