1966 header clip - NCRS Discussion Boards
1966 header clip
  • Keith M.
    Infrequent User
    • April 30, 2001
    • 27
    1966 header clip
    question...should the metal clips (that hold wiring) under header panel have paint on them,and is the starter brace bolt to block(on 427) cad (zinc) or phosphate...thx keith
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1966 header clip
    The clips should be black.
    • Keith M.
      Infrequent User
      • April 30, 2001
      • 27
      thank you for the help
      • Gary B.
        • February 1, 1997
        • 7077
        Russ,
        Painted? Or rubber coated?
        Gary
        • Brian K.
          • May 31, 2004
          • 358
          My original clips had a black rubber coating on them.
          • Russ S.
            • April 30, 1982
            • 2163
            A portion of the clip is rubber coated-not the stud portion.
            Originally posted by Gary Beaupre (28818)
            Russ,
            Gary
            • Gary S.
              Super Moderator
              • February 1, 1984
              • 460
              Good explanation at this search thread. Picture below shows green zinc (see lower left one) and rubber dipped.
              https://www.forums.ncrs.org/showthre...der+wire+clips
              Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
