54 W. washer hose - NCRS Discussion Boards
54 W. washer hose
  • Brad H.
    • August 12, 2007
    • 724
    54 W. washer hose
    I have been trying to get the braided hose set for my 54. Actually only need the single long hose from switch to jar lid. Supplier's say they are waiting and waiting. Any other sources or someone who may have extra. Thank you, Brad.
  • Leif A.
    • August 31, 1997
    • 3654
    Re: 54 W. washer hose
    You say the "supplier's" are waiting...have you tried the good Doctor?
    Late 1953-Early 1954 Corvette Windshield Washer Hose Set with Plastic T Pipe Connector. CAVEAT EMPTOR: Use this if you have a Vacuum Pump; that's after 1953 VIN # 180 approximately to 1954 VIN # 548 approximately. Includes both a washer fluid hose set & a vacuum hose set. See Noland Adams "Corvette Restoration Guides" for routing. NOTE: Ours was & still is the most accurate replica down to the manufacturers identification pattern on the surface as well as the ID, OD, wall thickness & material.
    Leif
    • Brad H.
      • August 12, 2007
      • 724
      Thank you Leif...I will try them. Brad.
      • Chris S.
        • January 1, 2000
        • 1068
        I assume you tried Carol at Grossmuellers.
        What do you mean "braided"
        They are not braided
        they are ribbed.....
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Brad H.
          • August 12, 2007
          • 724
          Yes ribbed... and they are wondering also why they haven't gotten their order's for that item in also. Thank's.
