70 original exhaust tip Clamp - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    What does everyone think of this clamp?
    Kind Regards,
    Bill
    • 15599
    Re: 70 original exhaust tip Clamp
    [ATTACH=CONFIG]68531[/ATTACH]
    Kind Regards,
    Bill
    Bill
    Is there a letter on the top of the flat portion?
    • Bill L.
      • February 1, 2004
      • 1403
      Hi Terry,
      I asked and have yet to hear back. Should have a K.
      Kind Regards,
      Bill
        • 15599
        Hi Terry,
        Kind Regards,
        Bill
        Pretty sure you are golden with a K. Might be OK with nothing also, depending on the judge. At most with nothing on it a dot would be all they are worth. ALL the exhaust clamps and brackets are lumped together, so there is a lot to fit into a small point allocation.
          • 11643
          If you install it as-is on an original appearing car, I'd bet the judges forget to look for the K if it "looks like it fits."
          If you're restoring it for use on a restored car, check for the K, though I'd use it anyway in a location where you can't get at the K.
