Warning: Undefined array key 6774 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 65-66 Power Brake Master Cylinder without a floating piston bolt - NCRS Discussion Boards
  • Dale O.
    • May 31, 1995
    • 52
    I am rebuilding a master cylinder 65-66 pb master cylinder. I took it apart and it does not have the bolt that stops the floating piston. Has any one seen this before? Is the bolt really necessary? Should machine the cylinder and install it?
    • 43287
    Re: 65-66 Power Brake Master Cylinder without a floating piston bolt
    Dale------
    Master cylinder rebuilders often leave out the secondary piston stop screw. So, I expect the screw is not really necessary. I like to use them, though.
    By the way, the fact that yours is missing the screw probably means it's been previously rebuilt.
    • Dale O.
      • May 31, 1995
      • 52
      Thanks for the response Joe. What is strange the master cylinder was never drilled or threaded for the bolt. If what your saying is true I should not worry about drilling, threading and installing the bolt.
      • Robert N.
        • Today
        Guys,
        The screw is there for a reason. I had mine rebuilt 20 years age and never could figure out why 4 wheel disc brakes were terrible. Replaced seals a couple times and one time while reading instructions I saw location where screw was missing since rebuilder had left out. Another problem is seal kits with new pistons are not correct, not sure if they were too long or too short. Best advice when your rebuilding your master use existing piston with new seals and reinstall screw.
        Rob
          • 43287
          Dale------
          I'm surprised that the master cylinder was never drilled and tapped for the screw. As far as I know, these stop screws were used for 1965 and later dual master cylinders. Apparently, the master cylinder worked for about 50 years without the screw so I'd say it could continue the same way. I would not attempt to drill and tap it for a screw now.
          However, I agree with Rob. That's why I always install the screw. Of course, I do it on master cylinders that are already drilled and tapped for the screw.
