66 L79 oil pan wire clip? - NCRS Discussion Boards
  • Brian K.
    • May 31, 2004
    • 358
    I got another 66 small block oil pan question, did they use a clip mounted to one of the oil pan bolts for the starter wires or battery cable?
    Re: 66 L79 oil pan wire clip?
    Brian -
    No, they didn't.
    • Gene M.
      • April 1, 1985
      • 4233
      Brian
      I think you are referring to the clip that routs the two forward plug wires (cylinders 1,3 & 2,4). There is one clip on each side attached with a pan screw in the middle on each side on small blocks. They get partly covered by the "V" chrome ignition shields.
      • Brian K.
        • May 31, 2004
        • 358
        Thanks John and Gene, Gene your correct.
        • Brian K.
          • May 31, 2004
          • 358
          Does anyone know which oil pan bolt on each side of the motor gets the spark plug wire clips? I checked AIM and see no reference, since it was installed at flint engine plant.
          • Donald H.
            • November 2, 2009
            • 2589
            I recently put a new pan on my 66 L79, but the car is at the painters so I can't post a picture. What I did for the clips was use the shielding wiring covers (the V pieces) to determine which pan bolt the clips should be on.
            Don
            Don Harris
            Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
            • Jeff S.
              • July 31, 1984
              • 384
              Brian
              On the driver's side, clip goes under the 6th screw back counting from the front; that will be just forward of the dipstick tube contour.
              On the passenger's side, clip goes under the 5th screw back from front; that will be just about even with starter case projection.
              Although on different front-to-rear locations, both clips will end up at the apex of the 'boomerang' shielding pieces.
              • Brian K.
                • May 31, 2004
                • 358
                Thanks Jeff for this much needed info! Sincerely Brian
                • Jeff P.
                  • 799
                  I'm almost ready to paint my 68 L79 engine. Were these clips on the engine for painting? I had too much grease on them at tear down to tell if they had paint on them. Thanks in advance. Jeff
                  68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                  2014 Arctic White Z51 Vert. (Wifes)
                  • Jeff P.
                    • 799
                    I just found another post that Terry stated they are on at painting. Thanks, all.
                      • 15634
                      I am not sure which Terry you are quoting, however, my 1970 (January 14 engine assembly) has them painted. I would expect 1968 could be the same, but a response from someone with a 1968, like Terry Dusterman, would be more meaningful than my evidence.
                      • Jeff P.
                        • 799
                        Yes Terry, I quoted you from another thread related to the clips being painted. Thanks for your help.
