Mounting generator, 327, with Hooker Headers ? - NCRS Discussion Boards
  • Ed P.
    • August 10, 2014
    • 89
    I got a problem, had my 327 rebuilt, and had Hooker headers in stalled. Now how do in stall the generator since the old exhaust pipes had mounting holes for the lower bracket for the generator. The Hooker's do not? Can someone tell me how to mount the generator ?
    The top bracket is there?
    Help
    EDD
    • 43248
    Re: Mounting generator, 327, with Hooker Headers ?
    Help
    EDD
    Ed-----
    There is no GM bracket I know of that will accommodate your installation. However, I think there are aftermarket brackets that will. I'd contact Hooker for advice or contact a retailer like Summit Racing. Someone else on this board might be able to advise, too.
    My solution to your problem? Well, I'd never encounter it because I'd never install headers on a street engine and I have no interest in owning racing/off-road cars.
    • Ed P.
      • August 10, 2014
      • 89
      I am not worried that it is not original equipment, aftermarket is ok with me.
      thanks
        • 43248
        thanks
        Ed-------
        Yes, I realize that. If original was your intention you wouldn't be using headers. However, sometimes if a GM piece will accommodate an otherwise non-stock installation it's the easiest solution. For example, folks installing headers on a 1969-71 small block which originally used a partially manifold-mounted alternator, can use the 1972+, head-mounted alternator brackets.
        • Ed P.
          • August 10, 2014
          • 89
          thanks
            • 6950
            Ed, Have you tried to make some spacers between header and bracket and use of longer bolts?
            • Edward B.
              • March 29, 2013
              • 691
              Most of the header manufacturers sell alternator and generator mounting brackets. HERE'S the ones from Hedman, but they're all basically the same.
              Ed
              • Jim D.
                • 2885
                Lots of generic brackets out there. One of these might work for bolting your original"U"bracket to.
                • Ed P.
                  • August 10, 2014
                  • 89
                  Hey guys THANK YOU VERY much
                  i feel a lot better now that i can get a bracket
                  EDD
                  • Bill M.
                    • 1328
                    I put hooker side pipes on a 66 rat rod that I built. The bracket that jim shows came with the pipes. I bought a second bracket from Summit that bolts to the hooker bracket worked out great. I would send you a picture but I got rid of the car.
