67 327 350hp oil dipstick tube - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1588
    What color should it be?
    The repop I just received from the esteemed house in MI is chrome, my original shows alot of black and a slightly different shape but same height.
    Don
  • Larry M.
    • January 1, 1992
    • 2695
    Re: 67 327 350hp oil dipstick tube
    My original is steel. 1967 327/350 HP 26,000 mile car. The Judging Manual also states/confirms natural, unpainted steel.
    Larry
    • Donald H.
      • November 2, 2009
      • 2580
      Sounds like you got a 66 350 HP dip stick. Per the 66 TIM&JG for L79 350 hp 'The handle and skirt are chrome plated....'
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Larry M.
        • January 1, 1992
        • 2695
        I thought the OP was talking about the dipstick TUBE and not the dipstick itself. That is what the title of his post states.
        Larry
        • Donald O.
          • May 31, 1990
          • 1588
          My question is on the dipstick tube not the stick. For a 1967 327 L79 or 350hp
          Don
          • Donald H.
            • November 2, 2009
            • 2580
            Larry
            Woops! Guess I need to read a little closer.
            Don Harris
              • 43222
              Don
              Don-------
              I don't know of any chrome or black upper dipstick tube that was ever used for 1967 small blocks. The original tube was GM #3876784. I believe this tube was natural steel finish. However, it MAY have been electro-galvanized.
              In July, 1974 the 3876784 was discontinued from SERVICE and replaced by GM #3865664 which had originally been used for some 1965+ light trucks with small block. The latter tube has the same developed length as the former but has a very slightly different curvature. The most obvious difference, though, is that the 3876784 has a reduced OD for about the top 1" of its length. The 3865664 has no such reduced OD. Also, I believe the 3865664 was electro-galvanized.
              • David L.
                • July 31, 1980
                • 3310
                Don,
                The tread below might help.
                Dave
                https://www.forums.ncrs.org/showthre...bes-GM-3876784
                • Donald O.
                  • May 31, 1990
                  • 1588
                  VERY helpful.
                  Thanks!
                  Don
