1963 universal joints - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Got all new joints from corvette central and they are about 1/8" to wide. Called CC helpline and was offered no help except call LI Corvette. Anybody had this problem and found a solution? Thanks in advance.
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: 1963 universal joints
    Jerry,
    Do a search in the archivess and you will find part #'s for Federal Mogul joints that you can go to the auto parts store to purchase. These joints do not have a zerk fitting like original and are not expensive.
    Also, read about the axle flange because it can be bent very easily removing the old parts. I believe the half shaft joint are something like 3 5/8 cap to cap but not 100% on that.
      • 43277
      Jerry------
      If you're referring to half-shaft u-joints, the phenomenon you are describing is quite common. I think I can say that if you had NOS u-joints of the original part number you'd have exactly the same problem.
      I do not recommend installing them yourself. Take them to a driveline shop experienced in installing Corvette half shaft u-joints. An experienced shop will have the fixture necessary to support the flange while the u-joint is removed and installed. As important, they'll have the experience to do the job properly.
      • Larry M.
        • January 1, 1992
        • 2701
        What joints are you trying to replace?? Driveshaft or Halfshaft or both??
        I used Federal-Mogul joints without zerks when I did my car a few years ago. Job went smoothly, but it was a bit tough using my 20 ton press to punch out the original joints after 50 years. But I was successful.
        I can supply part numbers if needed/wanted.
        Larry
        • Jerry C.
          • November 1, 1995
          • 741
          Larry Thanks I could use the part numbers for U joint and half shaft.
            • 43277
            Jerry------
            The non greaseable (as original) Moog (Federal-Mogul) u-joints are as follows:
            driveshaft------#269
            half shaft-------#231
            The Federal-Mogul u-joints are fine and are configured very much like the original u-joints. However, my preference is Dana-Spicer even though some of the premium Dana-Spicer u-joints are no longer configured like the original u-joints.
            Original Corvette u-joints were manufactured by both Dana-Spicer (old style) as well as of internal GM manufacture. Half shaft u-joints were ALWAYS of the non-greaseable type. Most driveshaft u-joints were also of the non-greaseable type but some may have been greaseable.
            • Philip C.
              • December 1, 1984
              • 1117
              Jerry I have found that sometimes the retaining clips are too thick, this may be your problem......Phil 8063
              • Larry M.
                • January 1, 1992
                • 2701
                Driveshaft: AC Delco 45U0145, or GM # 89029327 or FM/Precision #269. About $20/each.
                Halfshaft: AC Delco 45U0123, or GM# 89029305, or FM/Precision # 231. About $20/each.
                I ordered thru local Chevy Dealer to get a club discount. U-joints were drop shipped to me from FM in Chicago. As of a few years ago, they were still USA made in Chicago.
                Larry
