Turn signal cancelling cam - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1593
    What I have, it has been in use since 1985 when I bought this 67 vert:
    https://www.paragoncorvette.com/p-35...lling-cam.aspx
    What Paragon says I need:
    https://www.paragoncorvette.com/popu...large/2797.jpg
    Which is correct for a 1967 standard column - non tele?
    Don
    PS
    The problem is erratic horn connection
    This is on order
    https://www.paragoncorvette.com/popup.aspx?src=images/Product/large/4354K.jpg
  • Peter M.
    • May 30, 2013
    • 361
    Re: Turn signal cancelling cam
    Hi Don,
    I agree with you, re. the black cam. That is how I remember them. I have a telescopic column out of my 67 waiting for me to take apart and will check the cam in it. The horn problems I have had to deal with in the past involved the horn button retainer, the rag joint or various grounds.
    Kind Regards.
    P.S. Check out the similar threads at the bottom of this thread.
