c2 Seat covering help - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2589
    I have new Al Knoch stuff (covers, foam, install kit, etc) for my 66 coupe. I took apart one seat bottom and back and media blasted and painted the frames.
    I have the Al Knoch video, and have successfully installed the bottom seat foam to the cover. However, when I place the cover/foam compo on the frame roll the cover over the foam and try to attached the 'S' clips to the frame lip, I'm having a problem. The edge of the cover material is a good 2" up from the frame and I do not see any way to push/pull the cover down and attach the S clips.
    In the video it looks relatively easy (of course the guy doing it says he has done about a 1,000). I think one problem is that my seat covers need to be warmed up some. I'm doing it inside, but I can't seem to stretch the vinyl at all, but in the video he seems to get some stretch as he pulls the vinyl down and wraps it around the frame lip.
    I'm looking for anyone who has installed your seat covers successfully that can give me some advice.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Wayne G.
    • April 30, 1984
    • 144
    Re: c2 Seat covering help
    Don,
    I've installed a complete set on my '61, similar and with the same amount of struggle. I used a high wattage commercial heat gun. Without that it is almost impossible to stretch the vinyl. A good hair dryer might work though it may not get hot enough.
    Other than strong hands and a cold beer that's all you need.
    Good Luck.
    Wayne
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11363
      I have also used a small hand held steamer to help make the vinyl more workable.
      • Donald H.
        • November 2, 2009
        • 2589
        Rich,
        I've been looking at them. Do you recall the make and/or model of steamer. I've been looking on Amazon and there are tons of them. I don't have a clue if they put out enough steam to work.
        Don
        Don Harris
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11363
          Don, This is the one I use. Best Buy typically has them in stock at the stores.
          Conair GS23
          It's a hand held unit which makes it easy to use and quickly heats up for simple tasks. I use it for seat vinyl and soft top rags. It even works great for the soft top rear windows. For soft top rags I use it on both sides and it makes the wrinkles disappear like magic. Sometimes it takes several heat/cool cycles on the tough wrinkles. There are much more expensive commercial type units on the market but they're bulky and take up much space and take longer to heat up.
          On the '67 I recently restored, one of the vinyl seat backs was assembled wrong. The previous cover installer pulled the top vinyl too much on one side and the cover top to seat top was crooked. It was unsightly. I worked the hog rings to release the incorrect tension and all was better. However this left a soft crease from the incorrectly installed vinyl to the rear cover now exposed. Several steamer heat/cool cylces and a good rest on the shelf made the crease disappear. I'm quite certain that with some warm moist heat on your vinyl it will make your covers slip over your seat frames much easier.
          P9230023.jpgP9230015.jpgP9230016.jpgP9230024.jpgP9230025.jpgP9230026.jpgP9230027.jpgP9230028.jpgP9230029.jpgP9230049.jpgP9230050.jpg
          Here are some before and afters of the soft top rag wrinkles disappearing using the same steamer.
          • Donald H.
            • November 2, 2009
            • 2589
            Thanks! I'll get a steamer and give that a try.
            Don
            Don Harris
            • Jerry W.
              • January 27, 2009
              • 588
              Had similar problem on 62 seats..wasn't smart enough to think of steam heat...took seats and covers to upholstery shop...problem solved
              • Phillip M.
                • September 30, 2006
                • 100
                Don,
                One "trick of the trade" that I learned at Corvette America's C2 seat cover install seminar (at Corvettes at Carlisle 2 years ago), was the use of talc (unscented), sprinkled onto the foam to reduce the coefficient of friction between the foam and the underside of the vinyl. This should help you stretch the vinyl over the seat side frames. Also, I applied the "S" clips first to the edge of the vinyl then hooked them to the frame edge by rolling the clip under the frame edge to attach.
                Phil
                • Donald H.
                  • November 2, 2009
                  • 2589
                  I give the talc a try. I purchased the install kit when I purchased the Al Knoch seat covers. The covers had the install pieces already attached. The wires and pull through clips and the S clips were already on the covers.
                  Don
                  Don Harris
                  • Paul Y.
                    • September 30, 1982
                    • 570
                    Don
                    I have heated wet towels in the microwave for wrinkles and put the vinyl in the dryer to heat it up to stretch. Always remember not too much heat.
                    It's a good life!
