1968 L79 Exhaust manifold - NCRS Discussion Boards
  • Jeff P.
    • 799
    I found two past threads on this subject. I'm restoring a 68 L79 with AC. My Rt hand exhaust is the correct 3872778 for June build according to JM. My lft hand is or really looks like 3872786 JM says it should be 3872765. I took a couple of pics. Thank you Jeff. image.jpgimage.jpgimage.jpg
    I apologize for being upside down. Just glad they came out.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • 43259
    Re: 1968 L79 Exhaust manifold
    Originally posted by Jeff Pollard (15573)
    I found two past threads on this subject. I'm restoring a 68 L79 with AC. My Rt hand exhaust is the correct 3872778 for June build according to JM. My lft hand is or really looks like 3872786 JM says it should be 3872765. I took a couple of pics. Thank you Jeff. [ATTACH=CONFIG]68192[/ATTACH][ATTACH=CONFIG]68193[/ATTACH][ATTACH=CONFIG]68194[/ATTACH]
    Jeff------
    It's a 3872765. You're just reading the casting number incorrectly which is quite common for casting numbers.
    The configuration of this manifold is uniquely applicable to the 3872765; it could not be anything else.
    • Jeff P.
      • 799
      As always Joe. Many thanks.
