Has anyone had issues with the Quanta reproduction 3882814 alternator belt? My 1970 P & A states in Grp 1.066 that it's outer circumference is 56".
The new Quanta belt I have here measures 57" outer circumference, and I think may be the reason it looks like this......
I have maxed out the alternator tension on the brace.
Or could I have a wrong pulley? The WP pulley is a smaller diameter than the secondary(rear) groove. The WP pulley was on the engine before and has the correct part # stamped on it's hidden face.
The alternator pulley OD measures apx 3.2" using a caliper. There is no part# on it but appears correct. I could not find part# reference and diameter/groove depth info using my usual resource data.The belt appears to sit in this deep groove pulley a lot. Did I error somewhere?
The belt I removed from this engine was a NAPA 25-7550 which spec reads 55.58" OC, and it looks like this.....
The belt actually measures 56 1/2" likely from age. It's configuration appears normal to me.
Guidance appreciated....No archive data available here.
Rich
Rich
