1967 Marlboro Maroon and 1970 Marlboro Maroon - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    Are the 1967 and 1970 Marlboro Maroon colors the same? I am getting ready to paint a 1970 in lacquer. Thanks for your expertise.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • David H.
    • June 30, 2001
    • 1526
    Re: 1967 Marlboro Maroon and 1970 Marlboro Maroon
    Yes, paint supplier codes are the same. See link below.
    • Mike E.
      • February 28, 1975
      • 5138
      Am I missing something here? Only the valspar codes are the same on that chart, and I'm pretty sure they were not an OEM supplier. My 67 and 70 maroon cars are both original-paint cars, and to my eye, they are different colors.
      FWIW, the 67 sales brochure never calls out Marlboro maroon. In one area it refers to "Madeira maroon", and in another area to "Milano maroon".
      • Bill C.
        • July 15, 2007
        • 904
        pretty sure they are not the same. I think the 70 color is more Maroon than the 67.
        the PPG and DuPont numbers are different between 67 and 70
        OEM are not the same.
        I can promise you the mix formulas are different as well.
        Only way to find out is to go to the paint store and ask the counter person to compare the tint ratios/weights between both and see if they are the same.
        My bet is they are not.
        Bill
        • Kenneth B.
          • August 31, 1984
          • 2089
          NO Not even close. The 70 Maroon has more red & the 67 has a more dark maroon color. My 70 LT-1 has original paint looks somewhat red in the sun.
          • Tom B.
            • March 1, 2002
            • 140
            Gm may have used the same paint code numbers in a different year but that was no guaranty they were the same colors. Usually different color.
            • Paul O.
              • August 31, 1990
              • 1716
              1967 codes
              972 Ermine White W612 8259 4024 1199 1911 3071 - 2661
              900 Tuxedo Black K090 9300 99 946 - 3069 - -
              976 Marina Blue Metallic L2934 13364 4850 1920 - 3743 GMA67:F 3680
              977 Lynndale Blue Metallic L3442 13348 4833 1912 - 7833 GMA67:977 3624
              980 Elkhart Blue Metallic MW6701 13347 4834 1911 - 7834 GMA67:980 3694
              986 Silver Pearl Metallic S536 32449 4621 1708 2422 3537 GMA65:QQ 3314
              974 Rally Red R1163L 71491 4688 1744 2453 7794 GMA66:974 3395
              983 Goodwood Green Metallic G1095 43652 4835 1913 - 7835 GMA67:983 3626
              988 Morlboro Maroon Metallic R2078 71584 4836 1914F - 7836 GMA67:975 -
              984 Sunfire Yellow Y806 81540 4711 1828 - 7807 GMA66:984 3523
              1970 codes
              972 Classic White W041 8631 5040 1802 2517 3627 GMA70:10 3465
              975 Marlboro Maroon Metallic R2078 2262 5131 2280M - 4117 GMA67:975 4195
              976 Mulsanne Blue Metallic L913 2213 5190 2262 - 4035 GMA70:26 4069
              979 Bridgehampton Blue Metallic L1945 2199 5132 2263 - 4058 GMA70:979 4002
              984 Daytona Yellow Y476 2094 5026 2119 - 3916 - 3893
              974 Monza Red R502 2089 5027 2120R - 3944 GMA69:974 3894
              986 Cortez Silver Metallic S010 2059 5032 2108 - 3928 GMA69:14 3927
              982 Donnybrook Green Metallic G1707 2200 5133 2267D - 4059 GMA70:982 4003
              992 Laguna Gray Metallic N753 2198 5134 2258 - 4057 GMA70:992 4005
              993 Corvette Bronze Metallic B1567 2264 5128 2376 - - - -
              • Kenneth B.
                • August 31, 1984
                • 2089
                THANK YOU I believe each year the Maroon paint was a different shade.
