Top Color for yellow '67 - NCRS Discussion Boards
  • Tim G.
    • March 1, 1990
    • 1414
    I know that the soft top color is called out on a tank sticker, but it's not clear enough to read from the tank sticker on a '67 I own. The car is yellow with black standard interior. Would a black or white soft top be correct for this car? I'm pretty sure it came originally with a black soft top from conversations with prior owners. The soft top has been replaced with a black one at this point.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Top Color for yellow '67
    Either would have been available with yellow.
    • Bob B.
      • January 31, 2007
      • 525
      If a dealer ordered the car for stock there is a 99% chance the top was black, a three color car (yellow/black/white)
      is a very tough sell
      • Loren L.
        • April 30, 1976
        • 4104
        If it is not called out otherwise on the tank sticker, my understanding is that the STANDARD color top is used, ie, black.
        • Bill K.
          • June 27, 2013
          • 48
          Tim, my tank sticker called out a white top. Have original photos that validate that.
          • Ralph E.
            • February 1, 2002
            • 905
            Tim, my tank sticker called out a white top for my Yellow car with white interior.
            But the black top looks better in my opinion.
            • Tim G.
              • March 1, 1990
              • 1414
              Interesting, I know Bill's car from post #5 is yellow/black with a white top. My yellow/white has a black top called out on the tank sticker. The sticker on this car is just too tattered to see anything about the top. Since it needs a new top, I suppose I can go either way.
              • Ralph E.
                • February 1, 2002
                • 905
                For me since the top is rarely up because I enjoy driving with top down it would have been better if I had replaced the top with a black top.
                The black tops seem to show less dirt.
                • Charles C.
                  • July 25, 2012
                  • 37
                  Tim,
                  You indicated you can't make out the tank sticker top info for your car. I looked at copies from some of my old tank stickers and noticed there is a tank sticker difference between the black and white top cars that might help you figure it out - if just a little info still remains.
                  On my yellow/black/black roadster it shows 8STD(space)TP under the Option No. column, and STD BLACK TOP under the description. On one of the white top cars, it shows 02C05BA in the Option No. column, and CONVERT TOP WHITE under the description.
                  So even if you can't clearly make out any numbers or letters for the top option, maybe you can look at the patterns of the numbers and letters for a possible match?
                  Charlie
                  Charlie C.
                  Unrestored faded '67 Coupe Lynndale Blue, Black Leather
                  Factory options: A01 C60 G81 J50 K66 L36 M21 N40 QB1 U69
                  • Tim G.
                    • March 1, 1990
                    • 1414
                    Charles, that's good information, but part pertaining to the top is missing. There's not much of a tank sticker left.
