Half-Height Nuts - NCRS Discussion Boards
Half-Height Nuts
  • Christopher R.
    • March 31, 1975
    • 1599
    Half-Height Nuts
    I'm reading my 1962 Judging Guide the other night, and on page 175 I find that the ground straps are attached to the exhaust pipe hangers on top of the existing nut with a "half-height" nut. There's a nice picture, so I now know what it is. I'd never seen one or even heard of one before.
    Does anybody know where I can get them?
  • Gary B.
    • February 1, 1997
    • 7078
    Re: Half-Height Nuts
    Chris,
    They sound like standard jam nuts, which are about half as thick as regular nuts. Here's a description:
    http://www.fastenermart.com/jam-nuts.html
    Gary
    • Christopher R.
      • March 31, 1975
      • 1599
      Thank you Gary. Looking through the AIM, I believe that they are p/n 124920. Section 8.900 of the Parts Manual describes this part as a cadmium plated 5/16-24 jam nut.
      Anybody know where I can find that size? I'm guessing my friendly local hardware store won't carry it. Is that size used for anything else? Also need a 5/16 external tooth lock washer to go under this nut.
      • Gary B.
        • February 1, 1997
        • 7078
        Chris,
        McMaster-Carr has zinc plated jam nuts in that size for about $5.30 per hundred, plus S&H, but their minimum order will likely be a killer. Your local hardware store might indeed have them. Cad plated ones will be much harder to find.
        Gary
        • Gary B.
          • February 1, 1997
          • 7078
          Chris,
          What's the part number for the external tooth washer?
          Gary
          • Joe R.
            • May 31, 2006
            • 1822
            Originally posted by Gary Beaupre (28818)
            Chris,
            Gary
            Hi Gary,
            I'm pretty sure there is no minimum order with McMaster-Carr. I've placed several small orders with them.
            Joe
            • Gene M.
              • April 1, 1985
              • 4233
              There are many, many suppliers for jam nuts and star washers on the interweb.
              • Christopher R.
                • March 31, 1975
                • 1599
                Chris,
                Gary
                The p/n for the external tooth lock washer is listed in my AIM as 178537.
                I found the lock washers today at my local Home Depot, both in stainless and in zinc plated. Home Depot also had 5/16 jam nuts. But only in coarse threads. Not in fine.
                • Stephen L.
                  • May 31, 1984
                  • 3162
                  Try this website for fasteners... huge selection!!
                  • Gary B.
                    • February 1, 1997
                    • 7078
                    Chris,
                    GM still sells toothed washer, GM # 178537.
                    Gary
                      • 43288
                      Chris,
                      Gary
                      Gary------
                      It's now discontinued. There might still be some of them around, though.
                      • Nicholas L.
                        • November 1, 1982
                        • 342
                        Here is another Corvette fastener website.
