1967 3888366 5 Blade Fan Black Color Shade ? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    I have acquired a original in exceptional condition. Not specified in the 1967 JG, and after a long archive search, I've found inconclusive data on the shade of black for these fans.
    This thread discussed that originals were dip painted, therefore should/could have drips showing, but no specifics regarding color. The fan is original but not sure what shade of original black it was.
    Is it Semi-Gloss, Gloss, or Semi-Flat?
    Rich
    • 6950
    Re: 1967 3888366 5 Blade Fan Black Color Shade ?
    Rich, in similar threads below there talking gloss, But I am thinking a semi gloss applied with a thicker coat will give you the result you'll want. a cross between the two glosses. sometimes the gloss looks like a mirror finish and really in my opinion its to much gloss. I would also note the Fan shroud if metal should be a close match to the fan.
    • Frank P.
      • April 1, 1985
      • 64
      Rich
      Krylon 1613. Must be 1613 and not 51613 (found in box stores)
      Frank
      • Harry S.
        • July 31, 2002
        • 5330
        I vote high gloss. Looks like semi gloss after a few days of driving the car.
          • 43247
          [ATTACH=CONFIG]67874[/ATTACH][ATTACH=CONFIG]67875[/ATTACH][ATTACH=CONFIG]67876[/ATTACH]
          [ATTACH=CONFIG]67877[/ATTACH][ATTACH=CONFIG]67878[/ATTACH][ATTACH=CONFIG]67879[/ATTACH]
          Rich
          Rich------
          These fans were GLOSS black. However, they were not a high gloss black (e.g. they were not the gloss level of air cleaner bases).
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11334
            OMG I don't know what to do. How about purple?
            I'm gathering that gloss is the typical flavor.
            I bet if I paint it outside in this crazy Florida January heat and humidity, it'll cloud up just right. Painting anything other than flat black around here lately has been a real challenge. I ran the A/C in the shop all day yesterday and about to turn it on any minute now as it's getting sticky out there again.
            Thanks gents.
            • Larry M.
              • January 1, 1992
              • 2701
              I think this is the right answer.
              Larry
              • Peter M.
                • May 30, 2013
                • 359
                Hi Rich,
                I use Seymour gloss black "LACQUER". It's not as glossy as enamel spray paints.
                Good luck at Lakeland, you've done a great job.
                Kind Regards
                  • 11666
                  Thanks gents.
                  You could try and paint it here in 20 degrees and lightly falling snow...?
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11334
                    Brrr, Then it'd come out black and white.
                    Sorry about the A/C speak. I keep forgetting it's winter down here.
                      • 11666
                      17 now, 14 by morning.
                      It's the coldest we've had yet this year. So far only used the snow blower once.
                      Oh, and I can't stand humidity, so I'll stay here for now.
                        Keep in mind that there was only ONE black prime paint system at St. Louis (sometimes referred to as "dip-primed", but it was actually "flow-coated"); every unpainted raw steel part, from alternator braces to wheels to radiator supports [except the birdcage], went through that Flow-Coat system on an overhead conveyor, got the same paint, and the same "semi-flat" gloss. Flow-Coat was a continuous circulating system that required about 300 gallons of paint to charge it, so there was no "changing the paint".
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11334
                          Thank You John....So I suppose my next question would be.....Were these fans painted in St Louis or at the manufacturer? In this case, Hayes-Albion Company. I haven't painted it yet, it's all ready, media blasted, dusted, ready and waiting. I have 9 types of black here.
                          1- Enamel Gloss
                          2 -Lacquer Gloss
                          3- Lacquer Semi Flat
                          4-
                          Enamel Semi Flat
                          5- Enamel Flat
                          6- Lacquer Flat
                          7- Lacquer Semi-Gloss
                          8-
                          Enamel Semi-Gloss
                          9-
                          Enamel Low Gloss
                          My Semi-Flat is the Krylon 5-Ball Industrial Lacquer and I also have a good supply of the Semi-Flat Krylon Enamel. Would you recommend one of those? I'd really rather use a enamel for longevity.
                          Rich
                          • Don H.
                            Moderator
                            • June 16, 2009
                            • 2269
                            I vote no. 1
                            • Larry M.
                              • January 1, 1992
                              • 2701
                              Originally posted by Don Hooper (50543)
                              I vote no. 1
                              I agree. If you feel it is too glossy after painting, let it dry good and then use some some polishing compound or 0000 steel wool to reduce the gloss to whatever level you desire.
                              Larry
